Will CSUSA razor heads screw into PSI handles?
thewishman
Reynoldsburg, Ohio, USA.
I had to trade out a Berea Mach3 handle with a Fusion head from CSUSA. The Fusion head fit in the Mach3 handle, but the reverse does not fit.
Do the PSI and CSUSA razor threads match?
Dan Masshardt
Mechanicsburg, PA
I had to trade out a Berea Mach3 handle with a Fusion head from CSUSA. The Fusion head fit in the Mach3 handle, but the reverse does not fit. Do the PSI and CSUSA razor threads match?
Did you fiddle with it a little bit? I'm pretty sure I've switched Berea Mach 3 with csusa fusion both ways several times.
thewishman
I'm trying to figure out if the PSI toothbrush heads (same threading as the razors) will fit in the CSUSA razors. I like the CSUSA razor design much better than the competition - the screw together components are nicer than the press fits and the plated button on the Fusion is much better looking than either of the others. I just don't have one of their handles right now to check.
