Spring Blossom Rollerball Pen Kit
Drill Bit required -- 14.5mm"
when drilled the blank hole is just too small for the tube!
I forced the tube into the hole and split the blank.
I re-drilled the hole into another blank still too small.
I mic the drill and bit it is just too small for the tube.
I did make it work by putting sandpaper on a dowel rod - then on the lathe and rimed the blank hole until the tube slid in with ease.
I have never seen this have you?
paul
paul
