okiebugg
With all of the talk lately of inlay, this is a simple project to make to be sure that the inlay material you cut is consistently the same thickness. Takea about an hour and saves the headache of not knowing if your inlay materiak is the same thickness. cut the fence to the width you desire. I used 3"
I sure hope I posted this correctly.
The reason I'm posting this, is I made this fence a few years ago. I was cutting deer antler without using this fence, feeding it by hand when I hit a soft spot in the antler and......I got banged. cut my fingernail in half, cut the end of mi left index finger into the bone, and nicked the first joint on my finger. Had to remove the fingernail and 8 stitches
Using your bandsaw fence, cut a kerf with the bandsaw 1/2 the length of the board
Cut the top fence 1 1/2" wide the same length as the first board
slide the board with the kerf into position with the blade just clearing the wide board in the center.
Put the narrow board on top of the wide board close to the blade. Clamp lightly. Using a small ruler, set the upper fence the distance from the blade that you want the inlay material thickness. Clamp at both ends. re-measure your desired width and adjust in necessary. Lay your material on top of the bottom board,against the upper fence and feed slowly into the blade. The slower you feed, the more consistent your cuts will be.
from another angle
finally, a piece of maple cut for inlay
another view
from another angle
another view
