pauljas
With the help of several of you, I am now to the point of feeling pretty comfortable with the attention to detail required to successfully turn a Perfect fit pen kit. Most recently, I went to assemble the pen and when I went to test thetwist mechanism in the lower part of the kit, it would not click into place. Instead, it just drops back, asthough there is nothing to hold it in place.
Wanting to learn from my mistakes, I explored where I wentwrong by:
I purchased the kits from Bear Tooth Woods as I understand theysupport IAP and all Perfect Fits come from the same factory.
My questions for everyone:
Also, if someone would be so kind as to send me a privatemessage on how to post pics, I would appreciate the help as I can't seem tofigure it out.
Paul
- Measuring the lower half of the pen, compared to the brasstube: perfect match
- Checking the assembly of the nib and twist holder: noproblems here, everything is nice and tight
- Install different pen refills and twist mechanisms: sameresult, would not function
- I removed the twist mechanism from a working, assembled pento see if it would operate differently and it had the same problem on the "problem"pen and other twist mechanisms worked fine on the "working" pen
- The last thing I did was to remove the nib andinstalled a new nib and THE PEN OPERATED PERFECTLY!
- Can anyone spot anerror on my part?I really would love toknow where I went wrong, or
- Should I reach out to the seller and ask for areplacement?
- Have you ever had this problem?
Paul
