AKBeaver
My El Cheapo $50 drill press had quite a bit of wobble when the quill was extended. I checked run out with my dial indicator and found the chuck had over 10 thousands of run out. I removed the chuck and the shaft only had a little over 1, but I found that it jumped to over 5 or more with the slightest of side loading of the pulley. I did some more checking and the bearings did not turn very smoothly. I have new bearings on order, but am stuck on how to remove the bearings inside the spindle sleeve. They are pressed into the sleeve, but there is no real meat to use a puller. Any suggestions?
