Charles
Ok, guys. I have a center drilling clamp from PSI, I have used for 3+ years. No real problems till now. When I have it centered under the drill bit and push the bit into the grove it is aligned perfectly. Drill press is plumb and pushing straight down. When I place a blank in the jaws and drill; the top hole will be perfectly centered and where the bit exits is off center. I can not figure what is causing this. It is as if the bit is traveling at an angle insted of straight through the material. Any help appreciated. BTW I checked the alignment and tightness of the screws of the vise and tightened all screws and still got an off centered exit hole. Ok, guys what are your thoughts??????
