A pen for a 'Don'
See more from skiprat
skiprat
Passed Away Mar 22, 2022
In a Skip in Wales
I have a buddy in USA that is a 'Mafia Don' ( well he likes to think he is ):biggrin:. This is for him.
Some segmented Burnt Copper and Pure White pr from the Princess ( of course :wink: ) Closed ended on a Jr Retro. I kinda like it, but it was a bit tricky to do the segmenting with a router.
Critiques or comments welcome.:wink:
gvanweerd
Kuna IDaho
I love it!! Way to go! I've been wanting to do something like that for my pool playing buddys. but i haven't figured how to make the segment as of yet. jealously i say GOODJOB!
OKLAHOMAN
Costa Rica
You never fail to come up with outstanding pens but Skippy,Skippy,Skippy you know there's no such thing as the "Mafia" just a bunch of eyetalins that like to hang out eat pasta and own strip clubs .
skiprat
In a Skip in Wales
Thanks for the comments:biggrin:
LOL, I dunno about that!!! This guy has his own personal hit man with missing digits:biggrin::eek::wink:
NewLondon88
Local Chapter Leader
Claremont NH
anyone want to buy my lathe and all the blanks you can fit in your truck?
After this, I might just hang it up.
Beautiful work, Skip
workinforwood
Eaton Rapids, Michigan, USA.
That's outstanding Steve! I love the segmentation work and the sharp clash of colors are a major compliment. I know this guy Mafia Don too. He's really high ranking in the world of illegal Black Jack back behind the Ole Spagetti Factory.:biggrin: His Dealer..oops, I mean hitman, is also the garlic chopper. Don likes his garlic sliced super thin so it melts in the pot.
BRobbins629
Passed Away Dec 28, 2021
Richmond, VA, USA.
If its the same guy I'm thinking of, if he sees one sanding line on the finish its curtains for the penmaker. You have to be pretty brave to make a pen for this Don.
I too have been wanting to try my hand at making a pool cue pen and the points are what have me held up. You did a good job with yours. Would it be possible to give us some detail and maybe a photo or two how you did the point work.???? Thanks for showing.
workinforwood
Deja vu. You must have been sleeping JT..I can't find the post, but it's already been posted how he <The Stevemaster> does this, with pics and all! :biggrin: I believe it was in a pool cue pen thread in the Penturning section where someone else was trying to do this. It's impressive and a bit scary :eek:
skiprat
In a Skip in Wales
John, I didn't take pics of this one but you can see my little setup in the link.
I don't have the means to square up a blank perfectly ( good table saw ) so I used this setup to index the 4 sides of the Burnt copper blank. I then spilt the blank into 4 on a bandsaw. I just needed to save the perfect corners.
Then using the same setup but with the router set to 45deg and with the cutter edge exactly on centre to my chuck / indexer thingy, which was set at a slight angle to the table travel, I cut the V grooves in the white PR.
I glued one piece of the BCopper into the groove then did the opposite side. In other words 1,3,2,4. This is because the cuts must go beyond the centre point of the white blank. Hope this makes sense:confused::biggrin:
http://www.penturners.org/forum/showthread.php?t=49774&highlight=compound+table
Jeff is that the link you are talking about that Steve posted???? http://www.penturners.org/forum/show...compound+table If not I would be very very interested to find it.
skiprat
In a Skip in Wales
Perhaps Jeff was thinking of this one? This was a real pig to setup and I wasted tons of pr blanks before the penny dropped:mad:
But now with the setup on my drillpress / compound table, I find the flexibility almost limitless.
The cuts in the second pic are correct but the ones in the third pic are what I was convinced that they should look like. The router bit used here was a 60deg (included) perfect point bit.
I don't believe that it's possible to do 'long' angles and still only used two parts. Beyond me anyway:biggrin:
hebertjo
Phoenix, AZ, USA.
Simply awesome skiprat!
When you look close at the lower section can you see where the 4 different sections of brunt copper connect? Also, did you just CA the sections in or did you use your heat and compress trick as well?
skiprat
In a Skip in Wales
John, I didn't need heat with these joints:biggrin: The joints are just barely visible because of the difference in colour in the burnt copper pieces.
Thanks again for the compliments and comments:biggrin:
workinforwood
Those are not the links. I remember we had a big debate about how to achieve these long skinny points, and Steve said he uses a router bit and showed pictures of a v bit that he uses and most of the rest of us said it can't be done that way, and we were all wrong, but I still say I can make those real easy just using my scroll saw, but the lines won't be as 100% straight as a router on a fence, but the seems will be flawless. It's fortunate that in life there is almost always more than one way to skin a rat.:biggrin:
Steve..that sample pic up there at post#22..I remember that too, and that is just crazy! I think you stopped making pens a while ago and have taken up the hobby of photo shop!:eek:
OKLAHOMAN
Costa Rica
Did I ever mention my friend "Johnny No Fingers" :cool:?
[quote=skiprat;944202]Thanks for the comments:biggrin:
LOL, I dunno about that!!! This guy has his own personal hit man with missing digits:biggrin::eek::wink:[/quote]
nava1uni
San Francisco, CA, USA.
I don't like it and think that you should send it to me to dispose of so the mob won't come after you. LOL
As usual your work astonishes me. Very beautiful and very nice lines.
redfishsc
North Charleston , SC
Skiprat, I make it a point to see anything you post when I get the chance to come by here. And I'm NEVER disappointed.
That's an amazing stunt. On a scale of 1 to 10, I give it a "damn!"
OKLAHOMAN
Costa Rica
Well today I was blessed with this Skiprat original and officially deemed him my #1 CAPO (Crazy A$$ed Pen Oracle).
Until you hold one of his pens in your hands you really don't and can't appreciate his workmanship. Thank you my friend!
skiprat
In a Skip in Wales
LOL, Glad you got it Roy. USPS ain't all that bad after all:wink:
Across the big pond in around 10 days.:eek:
What Roy hasn't said was that he was going to put his hitman onto me if I didn't get my act together with my CA finish, and sent me some cool blanks to have a go with:biggrin: so..........Thank YOU sir:wink:
Merry Christmas guys:biggrin:
