Christmas pens for 2023
See more from MDVolle
MDVolle
Lake Elsinore CA
So the last 8 weeks "hobby time" has been focused on using wood actually found in the yard - downed branches and trimmings - "Found On Ground" as one turner called it.
Which leads to some challenges in finding enough good enough wood to make a blank from - especially with bug damaged branches and limbs.
The first challenge was just cutting up a bunch of pieces and seeing what was inside - I made 5-7" pieces with the chainsaw and then split them open on the bandsaw. Our yard is 2 1/2 acres of mostly Coastal Oak with some Manzanita - The oldest Oak is between 150-200 years old but most are much younger.
A downed branch from the old oak yielded several pieces like this one on the bandsaw -
While there might not be a single piece that's completely undamaged, I decided to see if I would work with the damage and just make a pen anyway.
There were, of course, more than one failed experiment and pieces that just flew off the tube after starting to turn, but I found a balance of how much had to be solid to still be turnable.
The next challenge was what to do with all the voids - some bug trails are packed tight with the chewed up wood and if solid, it actually turns and finishes but many sections come flying out as you turn into the bug trails -
Some experimenting resulted in finding that I could fill the voids with ground turquoise and thin, penetrating CA - but working in thin layers was essential to saturating the entire fill with glue (turn through the glue saturated part and the loose powder would come flying out at me) so it also meant trying to get close to size before doing too much filling. Powdered Copper also works but just doesn't go well with many of the pen kits.
One problem was that if I just sanded and then finished the pen, like solid wood, the turquoise was dull and lifeless - so it has to be polished before finishing -
Queue up several more failed experiments - trying to polish the CA/Turquoise resulted in getting the wood parts "dirty" and filling in some of the grain with powder, polishing compound or even stains from the polishing touching the metal bushings at the ends - but the stone part looked great...
The end game was to combine finishing and final sanding into a hybrid sequence - I actually sand the pen to about 2000 and then take it off the bushings and put it between finishing non-stick cones. These don't lend any metal or color to the polishing -
Next, I actually coat the whole blank with a thin layer of the penetrating CA and then sand again - through the top of the CA to the stone chips and the top of the wood, but the pores and grain are now filled and don't gather debris from the polishing -the whole pen gets polished/burnished - the wood to a near shine but the stone to a glossy finish - Then I can finally start the actual finish layers of CA - and once sanded and polished, the stone underneath now looks shiny and polished as well - Preceding pens definitely omitted from the photos... some were downright ugly -
I am far from mastering the technique but its improving and all of this years Christmas Pens are from the yard - There are 16 total but some got wrapped before the photo...
keithbyrd
Mount Wolf, PA
Outstanding work! I think you did a great job on those! I am sure there are going to be some pleased recipients of those gifts!
Not all of those are out of the oak - did you use some of the Manzanita you mentioned? I have made several Manzanita pens and love the wood!
Great job and Merry Christmas!
derekdd
Wisconsin
Wonderful work and way to take advantage of the fallen wood.
I'd be tempted to use colored epoxy but the turquoise sure turned out pretty.
JohnU
Ottawa, Illinois
You did that old piece of limb justice! If I had those trees in my yard I would need a bigger shed to keep all of the fallen limbs in! They all look beautiful but I am a huge fan of the oak and its character. Great work!
MDVolle
Lake Elsinore CA
I did - and its great wood - it polishes to a semi-gloss even without a finish - the blond and brown in one piece is common - Turns great and is quite hard - just a little harder to come by -
MDVolle
Lake Elsinore CA
Fortunately, I can "store" a lot of dead limbs on the trees if they aren't posing a hazard - but I do have a job box full of Manzanita and a couple piles of potential Oak - and almost equally important, a fireplace for things that aren't usable or interesting.
MDVolle
Lake Elsinore CA
I'm hoping to use some that have fire scars - but will have to fill the space with clear epoxy to make a blank - they aren't stable enough to bore through - so planning to play with some epoxy soon - would like to be able to more or less stabilize with epoxy but may have to go the Cactus Juice route - want to be able to see into the voids rather than blank them out.
