Ultra Carbide Chisel System compatible NR
Lucky2
New Brunswick/ Canada
Probably the same size that came on the tool, can you not measure the one that came on it? If you can't measure off of an old/used one, then you could check the info on the PSI tool to get the proper size. I could tell you a size, but it could be he wrong one. So, I think you would be better off to check out the PSI site to get what you need.
Len
Aaturner
Belton, Texas
Len
PSI does not make a negative rake cutter. So I was trying to substitute an Easy wood negative rake cutter. Could not find sizes on psi. Not sure easy wood has sized listed either. I can measure mine. But not having easy woods measurements leaves me with no answer.
qquake
Northern California
I use a homemade handle that is made from 1/2" square steel bar. The EWT negative rake cutter I purchased is the 2" radius Ci1, I believe. I bought it at Woodcraft. It measures approximately 15mm.
