Thanksgiving penmaking marathon
See more from jalbert
jalbert
Louisville, KY
This past long Thanksgiving weekend ended up being somewhat of a penmaking marathon. Here are the fruits of my labor:
1. A commissioned piece in a resin that Jonathon Brooks cast, and the customer sent me. It's a three sided sculpted pen, and is fitted for a Pelikan M800 nib. I fabricated the clip from stainless steel.
2. This is another sculpted pen, which I made on a whim because I really like this material. It's "lilac water" acrylic that I bought from Beartooth Woods. It is fitted with a Jowo #6 nib. The clip on this one is stainless steel as well.
3. This pen caused me a whole lot of grief--mainly because it uses a piston filling system that I had been working on, and finally got the chance to build. After three iterations, I finally got the mechanism right. It is made from a strata gem acrylic, and "milk chocolate" acrylic. The nib is a Pelikan M800 (I really like this nib), and the cap band and clip are bronze. I had some serious vintage European vibes running around my head while building this, and I feel like they really came through. I feel that this pen is quintessentially "me," as it embodies all the design aspects that I love.
TonyL
Georgia
Outstanding. I still can't get the inside of the barrel and transparent and scratch-free as you. I wish you would share the technique. Awesome work!
jalbert
Louisville, KY
Thank you Tony. I don't really have any secret or special technique for internal sanding. I use an aluminum rod with a slit cut in the end to hold a folded up piece of sandpaper, which is chucked in my lathe. I have a little container of water on the lathe bed under the mandrel so I can wet sand and not get water all over the place, and I just use that setup to cycle through all the grits.
mark james
IAP Collection, Curator
Medina, Ohio
G'Day John. I am a big fan of many of your previous works.
I have far to little experience with fountain pens, so in that aspect I'm Ill informed.
But for form, profile, colors, hues and general appearance, the third pen is very appealing. I have little exact variables to point to other than it simply looks "like a pen that is comfortable to use, and is visually distinct from most others."
All are wonderful, but the "Milk Chocolate" is a winner for me.
Cheers, Mark
jalbert
Louisville, KY
Cheers, Mark
Thank you Mark. That last pen is my favorite too. It's the perfect length/diameter for me, and I've been using it all week at work.
Curly
Saskatoon SK., Canada.
Always look forward to opening your threads.
The knurling on the last pen. Did you actually run a knurling tool against the part or did you index it and cut it in some fashion?
jalbert
Louisville, KY
Thanks Pete. I used a cheap knurling tool I had, however I ruined the first blind cap I made because I didn't go about it in an intelligent manner. I wish I'd had a wheel for my tool with a finer, sharper knurl, so that's probably going to be a future purchase.
