New Lathe questions
WriteON
Florida & Pa
Just got a new Jet 1015VS. The bottom of base (legs) are not 100% level/flat to each other. Lathe has a slight rock on the bench top. I shimmed and it's stable. I don't think the entire frame/base is off...just the footing. I can live with it if everything else is ok.
The main questions is the Break In. I do not see anything in the operator manual. I did not "break in" my other Jets. Is it necessary to run without a load for a while before using. It will only be used for pen blanks. Thanks, Frank
WriteON
Florida & Pa
I'm up and running.
Tim'sTurnings
Central Michigan
Your set up looks good. Where is the variable speed control knob? I don't see it in the picture.
When I bought my 1014 I didn't see anything about a break-in period so I just set it up and started turning.
Good luck with your new lathe!
Tim.
jimmyz
Providence Forge VA
Be careful when you retract the tailstock. I went too far and the quill got jammed up. Stop when the autoeject releases the live center.
WriteON
Florida & Pa
Tim.
Knob blends in. I let it run a little and rechecked the belt tension. Drilled a few blanks... I'm ready to turn.
Gotcha. Thanks.
WriteON
Florida & Pa
Nice, enjoy. Glad you have the vac setup on it too!
Thank you.... safety first......each and every time.
Here's the Jet's first born. It's a fun kit...great gift for police, military or firearm collector. (but the 30cal bolt is still the coolest and best value)
