Gunmetal nuts
See more from Buzzy
Buzzy
Quebec, Canada
After my first attempt with hex steel nuts, I took up Curly's suggestion to use a gunmetal finish on another pen. I used Express Rust Blue so I had to boil the parts and I did 7 passes. I'm really happy with the look but it's hard to take a good picture of it.
I did a double tube pen hoping it would weigh a quarter pound (113g) but it's "only" 86g. It's still a nice weight though :)
Curly
Saskatoon SK., Canada.
I'm very glad the finish worked for you. It looks good.
If I might make another suggestion. Instead of using nuts why not get a bolt and cut it to length and drill it out. Then you have less to turn down and already being round won't thump and pound since there aren't 6 corners to remove. If you can dril a nut you can drill a bolt too.
Buzzy
Quebec, Canada
I think it would be harder to drill a hole in a bolt than to enlarge the existing one in a nut. Actually it's not that bad to have to remove the corners so I don't think it's worth the effort.
More4dan
Katy, TX
I've drilled a bolt once to make a pen. Only took an hour or two and a couple resharpenings of the drill bit. So much work I made the next one out of aluminum and turned it to look like a bolt.
