Two New Kitless FPs
See more from Sandsini
Sandsini
Lake Arrowhead, California
I have two new pens done in the style I have been pretty much exclusively working in lately.
The first is in Alternate Cumberland with black AA end pieces and section. The Nib is a #6 Jowo Ruthenium EF.
The second has been done in Eugene's Matrix in Black also with black AA end pieces and section as well as the cap. I originally made the section for this pen in red AA but I didn't like the color match so I borrowed the section from the Cumberland pen for the photos. Since this pen sold within a couple of hours of my posting it, I guess it gets to keep the black section! That means back to the lathe to recreate the black section for the other pen.
C&C always welcome.
More4dan
Katy, TX
Beautiful pens. Pen Dimensions? Thread sizes used?
Love the matching diameter between the body and cap.
I've been working on a similar design out of stainless steel, aluminum, and brass using 9mm x .75 for the front section and 11mm x .75 for the cap. I'm able to make the pen just under 1/2 inch.
Sandsini
Thank you for the kind words... The Cumberland pen is 15.74mm, in diameter while the black pen is 16.35. Both pens are 152mm long.
Both Pens share the same threading: 14 x .75 x 1 for the cap, 10 x 1 for the section and the standard Jowo threading for the feed.
The black end pieces are ~3mm wide.
The initial size I turn the section to, before shaping, is larger than a half an inch!
Eric
