I know there have been threads on this topic before, but it is always easier to ask than to search, right ?! :biggrin:
I know there are plenty of 7mm Twist Pen kits, and I know that PSI sells the Slimline Pro, which is an 8mm Click Pen.
I am quite sure there is no 7mm Click Pen kit on the market.
I just want to know if anyone has made, or tried to make, a 7mm Click Pen from readily available parts purchased specifically for the task or re-purposed from other kits.
The pen would use a 7mm tube or tubes, have a top push-button to extend/retract the refill, use a Parker-style refill, and have a minimum outer diameter of close to 0.330" which is the usual bushing size for the Twist Slimline pen kits.
