error of my ways
ichizlwood
mt crawford va
Help fix these problems..... first time turning this kind of blank.... night fire....sanded to 12000 then applied shellawax...where did the burn area come from at the cap....why the tear out....could I have filled it in with ca
Jim Burr
Banned
Reno, Nv
In my experience Terry, Colorwood or some of the other names it goes by is a bit soft. I have a couple dozen cutoffs from gun stocks. I stabilize them before use, problem solved!! I seem to be stabilizing a lot of stuff lately. Grain direction can also cause tear out. Try a sheer cut with a bowl gouge, that may help...JMHO
hard hat
Norfolk, VA
using a good sharp skew then a good sanding and you'll be set. apply thin CA to seal then sand to smooth, then apply CA finish. I've had little problem with them using this method
randyrls
Harrisburg, PA 17112
To add to what Brett said; After you glue the tube in, trim the ends with a sanding jig. Then put a drop of thin CA (Super-glue) on a piece of plastic Pid the end of the blank into the CA on both ends and repeat for the other blank. Check and remove any glue you get on the inside of the brass tube.
Terry; A sharp skew will cut a surface you can start sanding with 320 or 400 grit sandpaper.
ichizlwood
mt crawford va
Most Definately a dull skew...will sand and fill in with ca ...I like the blank and hardware...another project go be done again.... thanks everyone
beck3906
Belton, TX 76513
When stabilizing, do you get any colors bleeding over? What do you use to stabilize?
Smitty37
Passed Away Mar 29, 2018
Milford, Delaware 19963
Tear out is caused by tools not being sharp and or you were too aggressive.
Lin
Agreed, I have used that same blank with no problems sanding only to 600 grit.
ichizlwood
mt crawford va
This is a night fire blank from psi...I just drilled cut and glued ( 2 part epoxy ) the blank...after trimming I deburred....rough gouged from square to round then skew to size...sanded from 120 to 12000 then shellawax....
