Waluy
This 24k gold 30 Cal Bolt action was dressed in brass for a customer request. Working the brass was definitely a learning experience.
bling bling, was it a tube or was it solid brass you had to drill and then turn, I'm curious
Wow, 3/4"? You had to remove a lot of material didn't you?
Steve, That's a Classy, Brassy Pen.
You tend to go where others fear to tread,
To undertake that task would be too frightening for most of us, mere mortals.
Appreciate your Skill,
Congratulations.
Brian.
Did you turn it down on a metal lathe? To me it is "sticky" when you are holding the tool, not as bad as copper though.
if i may ask.. why did you put a tube in since it was solid metal already?
I'd echo this question. Why not just caliper the ID of the brass tube and drill the solid brass hole to match- this would prevent barrell failure from EVER happening because there is none. Im just curious if there was reason that i dont know because of my inexperience.
