Pair of Zen stamp pens
See more from ossaguy
ossaguy
San Diego
Here's a pair of Zen stamp pens done decoupage style.One is with flower stamps from Austria,the other is with Minnesota duck stamps.These duck stamps are bigger than normal,but fit a turned down Zen barrel perfectly.They cost more so I'm glad it only take two!
Thanks,
Steve
ossaguy
San Diego
Nice job, those are lovely. Mind reviewing your process for the stamps?
Thanks,
Jake
I pretty much follow the PSI video on YouTube, ( Search: Stamp Pen) and also there is a good tutorial here on the IAP in the library,to do them decoupage-style.I needed to do it that way on these because the stamps are jumbo sized,and they would overlap on a bare Zen tube.I think I turned the blank down to .460'',from the .512 finished size.( that fit the duck stamp just perfectly,I really lucked out)
Then built the med ca up to about .525'',then I use a sharp skew like a scraper (wrong.,I know..) to make it straight,down to .514",them MM to size,then buffed out.
On the other ones I've done,I send the decorated & sealed barrels to Don Vann for clear casting,then finish as normal.I like all the edges to mate up,so having a straight tube is needed for that.On the pens that will have curved shaped barrels,sending them to Don is the way to go.He does a great job.
Thanks,
Steve
