Making Beads on Lathe
See more from Youngturner101
Naperville
I have a whole bunch of questions when I start something new, and especially when I am struggling to find information on it, so bare with me please!
How would I go about making a wooden or acrylic bead on my lathe? I know that there were some kits on Penn State Industries but I didn't figure out how to do it.
I know there is something called "Beads" while turning where you turn the wood into beads but they are all attached. I am looking to make a round bead turned on the lathe with a hole in the middle.
Is this possible? if so, What mandrel would I need? or how would I go about doing it?
Thanks!!
KenV
Juneau, Alaska.
The techniques vary with size of the bead, and size of hole.
Larger ones can be turned on the end of a short spindle, and ends cleaned up with a shopmade small clamp chuck similar to those used to turn eggs.
1/8th inch all thread can be used as a mandrell. Have gone down to use of shank of 1/16 inch drill bit as a mandrel.
Small tools and "mag eyes " are a must for me
its_virgil
Wichita Falls, TX, USA.
How to turn big wood beads for Jewelry | Wood Beads
Turning a Wooden Bead - YouTube
Bead Expert - Timeless Wood - YouTube
Do a good turn daily!
Don
Thanks!!
nava1uni
San Francisco, CA, USA.
I have turned some from short dowels. I drilled a hole down the middle and then hold the piece of dowel in a chuck or collet chuck. You can then just turn a bead at a time and part it off.
