Need A bit of Band saw help
Peter Mcc
Central BC Canada
I got lucky yesterday and bought a 14" band saw for $125.00 runs great, came with guide fence mitre etc c/w abunch of blades varying in different widths.
I am looking to find a manual for it
It is a Rockwell Delta saw, there is no model no. anywhere on it, except for a tag with the serial #BV7762, anybody got an idea where to start a search?
Cheers
Peter
Dick Mahany
Palm Springs, CA
Peter,
Those saws were produced for many years with few changes. I do have a manual for a 1999 vintage saw, but if yours is a Rockwell Delta then it is quite a bit older. In any event I do have a .PDF copy that I could send you and it would likely get you at least the basics of what you may be looking for. Just PM me.
You could also try the Old Woodworking Machinery forum or Sawmill Creek forum as there are a lot of bandsaw folks there.
Wildman
Jacksonville, NC, USA.
wolftat
Product Reviews Manager
Fairfield, CT, USA.
I would need to see the serial plate to be sure but it looks like it is a 1958 made by the tupelo division. hope that helps a little.
REC # 1958
(1) Used 14'' Rockwell Model LBS2B Vertical Band Saw; S/N BF5865
Specifications:
Throat Depth........................................................ 14"
Wheel Diameter.................................................... 14"
Under Guide Capacity.......................................... 12" (nominal)
Blade Width Capacity............................................ '' to 1 1/8''(max)
Blade Length......................................................... 8' 10''
Blade Speed ........................................................ Per Customer's Requirement
Guide Post Size.................................................... 7/8'' Hex
Table Size (Main).................................................. N/A
(Auxiliary).............................................. N/A
Table Tilt............................................................... N/A
Table Height.......................................................... 52'' Nominal
Upper Wheel Adjustment....................................... '' Nomianl
Main Drive Motor................................................... HP
Electrical Characteristics....................................... 208/220/440 VAC / 3 Phase / 60 Cycle
Peter Mcc
Central BC Canada
Pic of serial plate
REC # 1958
Specifications:
Here is the only plate I can find on the saw
wolftat
Fairfield, CT, USA.
Does the saw look like this one sort of(minus the additional hinges)?
Peter Mcc
Central BC Canada
bandsaw help
I found a phone no. to call, was told by the rep. that my saw was built in june of 1957, and that it is a 28-290, tho mine has a different base, motor is underneath the saw rather than behind it.
thanks to all for your input
Cheers
Peter
Waluy
Olathe, KS 66061
