Thank you all for a great get together!
Dick Mahany
Palm Springs, CA
I just wanted to say thank you all for a great get together and also for making a new guy feel so welcome. It was truly a treat. Also thanks to Greg for the hospitality and nice bell demo. It was a lot of fun!
Dick
gketell
Local Chapter Leader
Pleasanton, CA, USA.
Thank you for coming, Dick. It was a pleasure meeting you. And thanks for sharing you cool threading setup. Hopefully we will see you at the next gathering too.
ldubia
Boulder Creek, CA
Thanks to Greg for hosting our group once again, Dick and Mark for joining in the fun, Greg for the Bell demo, Dick for the threading demo, Cindy for assisting in first aid, Jay for the great deals (sorry you are getting out of it), everyone for the good food and friendship, and all around for a wonderful day. I'm already looking forward to the next one.
gketell
Thanks for coming, folks. It was a ton-o-fun. If you have pictures please post them up.
Here is the bell that I made during the demo. Ken was lucky enough to take it home to his beautiful wife.
attachment.php
attachment.php
gketell
Hi Angela! We wish you could have been here too!
No first aid was necessary due to anything at the gathering. But both Larrys showed up with bandaged and splinted fingers. Luckily nothing permanent on either part but Mr Dubia had an argument with a bandsaw blade and Mr Brooks had a 3-way argument between his finger, the tool-rest of his lathe, and the block of wood that was turning on the lathe.
mharvey
Tracy Ca
Thanks ever so much for including me...I learned a lot already...
Nice to know there are others with too much time on their hands...and I found scrap materials and made a pressure chamber....not sure how much psi abs piping will hold...however...cast my first cactus....will turn this week.
gketell
Based on charts on this page ABS Pipes - Pressure Ratings I would not ever go above 75 psi. PVC is rated for several hundred psi if you need more. Flip side: when I was casting I used 50 psi and never had a bubble.
Gk
Dick Mahany
Palm Springs, CA
Gk
Just a side thought here. Pressure is pressure, but since water is barely compressible, but air is highly compressible, then a failure from excessive air pressure is far more dangerous than a burst from water pressure. Just a consideration for factoring in on the safety margin.
gketell
Very true, Dick. That is one of the reasons I stated my "max pressure" at lower than the lowest on the chart for the 3" pipe he is using. I tend to be Very conservative when it comes to safety. I like all my "bits" right where they are.
mharvey
Tracy Ca
thanks...solid place for information...I had it at 40-60 ...I still have a minor leak at the threads...I was thinking of fixing...but now...I will leave it there...that way...it will only pump more every few minutes and not have a risk of overpressure...since I throttled the PSI to 50....now i just need to figure why after four hours...at 60 degrees the alumilite was still pliable...guess I will let it sit over night for now on....
Jim Burr
Banned
Reno, Nv
Remember to that the pressure rating on PVC is fluid only!!! It is not rated for air and that is why there have been lots of threads admonishing this practice!!!
mharvey
Tracy Ca
I know you all just are dying to see my photo...in my profile...I reduced the size...as directed..but still get an upload failure?
Penl8the
Calgary
Hello Mark,
Can post larger size for these pictures?
Thanks in advance.
