Russianwolf
Need to do a bit of tweaking yet, but.......
It's REAL.
It WORKS.
It's ALL ME.
I give you the Antares Click
(wrapped in a defective Dichro blank that I had handy)
Parts are all Aluminum (made by a machine shop) and works on a 3/8 inch tube (same as the long click but shorter at about 69.5mm). Accepts either Parker refill OR Pilot G2 (and trying to get a Pilot V5 to work too, slight dif in the back end).
I'm planning to have these made for me in Alum, Brass, Copper and Stainless. The clip is still a question mark but will likely be powder coated black to work with all the metals.
She's 12mm in diameter so slightly larger than the long click.
Key things I wanted to achieve were, 1) no plating, and 2) adaptability.
It's REAL.
It WORKS.
It's ALL ME.
