Will Zen tubes, and blanks interchange with the Dayacom pen kits?
Marker
Ludlow, pa, 16333
I just received some Dayacom rollerball pen kits from timber bits.
I was just wondering if the blanks for the zen pen will would for these Dayacom pens?
I have not yet turned a zen pen. How long are the zen tubes?
I see that they are 10.5mm the same as the Dayacom.
Why I ask is because I just ordered a feather blank for a zen pen. I am thinking about using it on a Rhodium Dayacom rollerball, instead of a Zen.
ed4copies
Local Chapter Manager
Racine, WI, USA.
There is a common belief that if the "hole size" is the same for two kits, they MUST be the same diameter. This is NOT ALWAYS correct!!!!!!!!!
The important measurement for using a kit is the INSIDE DIAMETER, where your kit parts are "press fit". Very rarely does anyone even mention this measurement!!
BUT YOU SHOULD!!!
mredburn
IAP Activities Manager
Staff member
Fort Myers FL
I have the Zen tubes from Exotics. the bag is marked dayacom
Measurements
O/D .4005 -10.17mm
I/D.382 - 9.70
Marker
Ludlow, pa, 16333
I meant the pen kit called the "Dayacom", The ones that timberbits sells.
Anyway I ordered a few, and yes the tubes are the same, just the bushings are alittle different.
