Segmenting project
terryf
Pretoria, South Africa
I thought I'd give segmenting a try. A gemsbok horn cap with ivory lower body.
I cut the horn in two places and added two identical pieces of ivory in between the end pieces of horn.
They are now being glued.
The foreseeable problem is this - the horn is a whole lot softer than the ivory, so would you suggest turning down the horn first and then the ivory or vice versa.
Thanks in advance :biggrin:
skiprat
Passed Away Mar 22, 2022
In a Skip in Wales
Terry, I wouldn't have thought that the actual turning would be a problem. When I've turned soft and hard materials together, my biggest problem comes when sanding. But even that is solved by using a block behind the sandpaper. Good luck.
BTW, is the Gemsbok as notorious for cracking as the common buffalo blanks, after time?
terryf
Thanks for the tip re sanding :)
Im not sure what happens after time, only time will tell :D lol, no they dont crack unless you seal them. You dont put any finish on them at all and they're fine.
