corners jig?
Monty
Group Buy Coordinator
Pearland, Texas, USA.
Why waste time cutting the corners off? That's what the lathe is for. If it's just to cut down on the possibilities of chipping or a catch when starting, I just use a belt sander to take the edges off.
PaulDoug
Benton City, WA.
Here are a couple pictures of one I made. It works pretty good. I have only used it a few times.
ribanett
Kenner, LA, USA.
What Monty said is a lot faster. I have one of those jigs somewhere, wasted the money on it a couple of years ago.
Sberger
Rockport, TX.
Why? If you cut the corners off, then you will make it much tougher to find the center for drilling. One miscut corner and your perception is off. You buzz them off with the rest of the blank on the lathe anyway. Sounds like a government project idea.
PaulDoug
Benton City, WA.
Well, not here to argue with you, but I think I would mark the center of the blank before cutting... but I agree this kind of jig isn't necessary. I can't remember why I made it to begin with. For some reason it seemed necessary at the time.
PMisiaszek
Venice, FL and St Mikes, MD
What prompted the question about a corner-trimming jig is that I've ordered some Tru-stone blanks. and the instructions suggest trimming the corners to reduce the risk of chipping and/or cracking. Trimming corners is not something I'd typically do with a wood blank.
hunter-27
Passed Away Aug 14, 2013
Chadron, Ne, USA.
glycerine
Fayetteville, NC
If you have a disc sander, you can just drill the holes, glue in the tubes and then take off the edges on the sander. That's what I do...
Parson
Houston, Texas
Heat buildup is indeed an issue with trustone... so hit it just a tad on one corner, rotate it, hit it, rotate it, hit it, and so forth until each one is ground down a bit. This way you won't stay on one corner too long and get it too hot.
But I gotta tell you that I grind the crap out of my corners and yeah, it gets hottern' hades but I just keep going. It's never been an issue... no color changes, no tubes coming loose, nothing. Well, I did almost burn my fingers once, but I learned from that lesson :)
