Teeth
Jgrden
hOUSTON, Texas
Here is a question or a need that has to be answered. It will be hard to explain.
When making corn cob pens (sans resins) I have found that you cannot use a chisel to cut and shape the size of the pen. It is necessary to use sandpaper to cut it down to size which takes time and wastes sandpaper. Now then the obvious is to cut off the sides using a band saw - freehand. This is good but unreliable and a little unsafe.
Has any one created a jig with a rod that holds the blank an equal distance away from the blade as you shave off the sides?:confused:
If so, would you mind sharing your device?
low_48
Peoria, IL, USA.
John,
Have you tried using a skew? I soak the ends of corn cobs with thin CA, and haven't blown up one for years now. The skew cuts the cob really nicely
Monty
Group Buy Coordinator
Pearland, Texas, USA.
John,
Ditto, thin CA will soak in and make the entire cob easier to turn. In addition, a sharp skew is a +.
Jgrden
hOUSTON, Texas
Corn Cob
Here is what happened....
