Pen Case for bigger pens
Summit, NJ
I bought a 48 pen caes off of Arizona Silhouette and it will not hold any thing fatter than a zen or a slimline fatter pens like cigars etc. simply hit each other when you try to close the case and it finally damaged some of my pens.
Where can I get a good case that will hold fatter type pens? or are they all just cheap chinees cases and you can only use one side?
RDH79
Rimersburg, Pa, USA.
The cases I have I got from woodnwhimsies have the same problem. I just put slims on one side and the bigger pens on the other That way when its closed they are less likely to rub againest each other.
ssajn
Local Chapter Leader
Milwaukee, Wi, USA.
I also use the cases from Wood-N-Whimsies. With larger pens I'll put one in every other slot then do the same on top. They fit together nice and don't look over filled.
Just me 2 cents worth.
