Color casting challenged
Chuck Key
Richmond, Virginia, USA.
I would like to make a solid pink blank using Michaels casting resin.
Should I use:
1. White and red opaque pigments,
2. White opaque pigment and red dye,
3. Something else?
See title.
Thanks,
John
BRobbins629
Passed Away Dec 28, 2021
Richmond, VA, USA.
Liquid pigments such as mixol work great but definitely slow cure. May need to add heat with low temp toaster oven or the like.
Chuck Key
Thanks to everyone for your help with this. I was able to get the blank I needed using number two (2. White opaque pigment and red dye) from my original post.
Thanks again
John
