Table saw sled?
AZ
I am having a problem cutting my blanks. Since I am only fourteen I don't have a big shop. I have a ten inch table saw, and have been cutting blanks with that ok, but it just seems like there would be an easier way to make square cuts with it. So, I was wondering if any one has plans or pictures of a crosscutting sled for cutting pen blanks and such.
Thanks any info can help.
Clay
Lenny
Searsport, Maine
While a sled for your tablesaw is a very good idea (for other reasons) I would like to suggest you consider another option ....
http://www.grizzly.com/products/Finecut-Double-Saw-9-1-2-/H5412
This saw, or one like it, combined with a very simple wooden "miter box" style jig, would allow you to cut your blanks very accurately and with VERY little of the grain match lost to the saw kerf.
A tablesaw, even with a sled, is going to be a much more dangerous way to cut pen blanks.
Hello Clay
I clicked on your web site and the thing that strikes me is you make kitchen and bathroom cabinets??? Long step from making pens. Being that and you don't have a sled??? :)
Anyway if you google tablesaw sleds you will get a bunch of ideas and things that might interest you in other woodworking projects. Make a sled that can help in those aspects too. Here is a couple examples.
http://www.thewoodshop.20m.com/howto_crosscut.htm
http://www.familyhandyman.com/DIY-P...working-Tools/crosscuts-with-a-table-saw-sled
There is also a bunch of videos on utube that can help design one for your needs.
Here is a very good thread about some safety things and the older members here would love seeing some of the great names in this thread. Oh where has everyone gone???
http://www.penturners.org/forum/showthread.php?t=19031&highlight=tablesaw+crosscut+sled
Lenny
Searsport, Maine
As for making a sled for your tablesaw ... It's mostly a matter of positioning the "runners" so they will slide well in the mitr gauge slots of your saw. I have used hardwood (white oak, etc) but have found plastics to work even better. I used some cut off pieces of Trex decking once and it worked quite well. Fit the runners to the slots first, milling them nice and smooth, sneaking up on the fit till it's just right. WAX helps get things to slide freely. Once they fit place a few pennies under them so they stick up just proud of the table. Then with a little glue on them, set your table (mdf is a good choice) material onto them using the rip fence to help guide it reasonably square. You will later add a front fence and at that time will square it up to the blade. Once the glue on your runners has set up, take it off and flip the whole thing upside down and add some small countersunk screws through the runners and into the sled. Now test the sliding action and sand where neccesary (if it rubs anywhere you will see black marks on the runners) till it slides smoothly. Now your ready to add the front and back fence. Screw up through into the back piece avoiding the saw blade area. Both the back and front should be at least an inch taller than the saw will cut. On the front fence, use just a couple screws till you get it fine tuned for 90 degrees to the blade. Test Cuts with a wide piece till it's right! VERY IMPORTANT ... Add a block to the front of the fence to act as a guard where the blade will cut through. Here is one I made (which was really overkill even for handling plywood) .. http://picasaweb.google.com/toolmanlh/Misc03#5523281587463638450
http://picasaweb.google.com/toolmanlh/Misc03#5523281821825370098
Hope that helps you come up with something. PM me if I can help.
The one huge thing to remember is you are working with small pieces of wood and they will kick back on you so please use hold down clamps on both sides of the wood and keep the hands away from the blade. You have alot of pens in your future. :)
AZ
Hello Clay
Most of my crosscuts for shelves,cabinets I use a radial arm saw, but it is older and there is no blade guard on it so I don't even try to cut pen blanks with them.
Lenny
Searsport, Maine
I agree completely!
I urge you to give the Japanese saw a try. I think too often we, as woodworkers, forget that sometimes the simplest way is with hand tools! :)
I have cut all kinds of materials from hard burls to Acrylics to PR, with mine and it will cost no more than a good bandsaw blade would when I go to replace the blade.
rherrell
Pilot Mountain, NC
Here's one I designed. You can set it up to do just about anything.
attachment.php
attachment.php
I've made SEVERAL more jigs since these pictures were taken. The design is such that it's almost limitless in what you can do.:wink:
MAB11
Wichita, KS
attachment.php
attachment.php
These t-tracks are alot cheaper at McMaster Carr than Rockler.
ctubbs
Murray, Kentucky
Now that is one beautiful sled. Why don't you submit it and a wright up on construction to some of the wood working mags?
rherrell
Pilot Mountain, NC
Rick, how much would you charge me for one of those killer sleds?
I've been asked by several people and the problem is that not all table saws are the same. In order for ANY sled to work PROPERLY the runners on the bottom have to be an EXACT fit. That's impossible for me to do without having the saw to work from. If I make it and leave the runners off then I can't cut the kerf and square up the T-track.
PLEASE feel free to copy it, it's really not that hard to make.:biggrin::wink:
kludge77
Santa Rosa Ca
Clay
I've seen loads of really sweet sleds but since you asked for a simple square cutting sled, here's mine.
just 2 pieces of plywood on two runners. For others looking for a no frill blank sled.
Lenny
Searsport, Maine
Clay
Very similar to what I use on my bandsaw. Simply, no frills, but does the job effectively! :)
DBMyers
Louisiana
Here is a sled that I put together for blank ripping and cutting.
