RING MAKING
Skye
Rock Hill, SC
I don't know if you picked up on it or not but the guy finished the inside, parted it off, then slid it on a tenon on the waste block. It's just pressure fit into place. I've done one before just playing around and there's an art to it for sure.
BRobbins629
Passed Away Dec 28, 2021
Richmond, VA, USA.
I haven't done rings, but I have done a few centerbands by making some bushings with very narrow tenons and just mounting on a pen mandrel. Works for me.
ldb2000
Laurence Harbor, NJ, USA.
That link is a wealth of knowledge for making rings . He uses a jam chuck to hold the parted ring for finishing , pictures 9 and 10 on the second page . This is the only way I know of to this . I guess you could use the step jaws on your chuck .
That is a great idea Bruce , I never would have thought of that .
btboone
Roswell, GA, USA.
I do mine from a solid block glued up from 3 pieces, and turn the outside first, followed by the inside and part it off. I use an expanding aluminum mandrel to grip on the ring to finish the inner corner for side 2. A tapered scrap of wood can work well there too.
Halifax, Canada.
I've always been curious how you make the ones with the inlaid wood:confused: Don't answer if you don't want to give out any trade secrets:tongue::wink:
bad
Calgary, Alberta, Canada.
Bruce, those are amazing rings. When I get time after Christmas I'll have to give that a try. I doubt if they'll be as nice as yours. At least not at first ; )
Skye
Rock Hill, SC
Dang man, what do you finish those with?
btboone
Roswell, GA, USA.
I do a CA finish. I sand them with a drywall sponge, maybe 220 grit then a fine yellow sanding sponge, probably around 320 grit and polish from there. When I sand, I don't spin them on the lathe. I sand at a 45 degree angle, and that does a better job of smoothing the surface. The metal rings with the inlay are done by a proprietary method that I came up with. I'll keep those a secret.
ed4copies
Local Chapter Manager
Racine, WI, USA.
Bruce,
I am certainly NOT trying to tell you how to do YOUR business.
Have you TRIED buffing? Seems like it would be faster and the results on a Beall type system ARE amazing.
Just a thought.
btboone
Roswell, GA, USA.
Hi Ed,
I've tried different ways. I do buff at the end with my 3/4hp 3500 rpm buffer. It goes pretty quick and I need to be careful not to burn through. I don't sell that all many of them, which is a good thing because they take a lot longer than the titanium ones with all the setup and gluing and finishing, and they sell for less money than the other things I do in the same amount of time. I need to compensate the ring size numbers for the finish and need to be sure they are dead on size when I'm done. There's a very specific way I need to do them in order to ensure the laminations are dead center. The hand sanding part only takes about a minute or so, and I find that does a better job than sanding on the lathe, which leaves lines, so I would need to use finer grits. It only takes a few swipes with the right grit sanding sponge to be sure ther are no bumps or imperfections in the finish.
Every once in a while I'll have a whole wedding party get them, like in this case, where the groom's last name was Wood.
ed4copies
Racine, WI, USA.
"Every once in a while I'll have a whole wedding party get them, like in this case, where the groom's last name was Wood."
Sure, Bruce.
I suppose his first name was "big" or "hard" and the bride to be was "Strokin"???
(I kinda figured you HAD thought of that, but ya never know!!)
btboone
Roswell, GA, USA.
Here's one I did today. The wood ring is a companion ring to my Sculpted Pear ring and is made in Koa. It is a bit lighter in person. The two rings nest nicely on a finger.
ed4copies
Racine, WI, USA.
It's beautiful work, Bruce.
Why would they want wood for a wedding band and metal for the engagement ring?
Does wood not like holding stones?? (Just a guess)
btboone
Roswell, GA, USA.
The Sculpted Pear is the main show on her finger. The wood is just along for the ride. I wouldn't trust wood to hold a diamond. It's not stable enough for that.
btboone
Roswell, GA, USA.
Chicagohand, look up some old posts that I made. You can see some of the equipment in the posts about my Spyra and Flames rings.
Gary Max
Southern Kentucky
Just don't let your wife look at his web site----Bruce makes some of the most awesome rings on the market.
Oh ----Bruce what to I use to polish the wifes ring--after two years it needs polished???
btboone
Roswell, GA, USA.
Gary, the best thing for polishing a ring is a polishing compound made for stainless. I use a white waxy compound on my buffing wheel, but lots of other fine abrasives or polishes could work, like car wax, simichrome polish, Zam, Blue Away, and others. Some toothpasts might even do OK. The trick is to get out any fine scratches with 400 grit or so paper before polishing. I wet sand with WD-40 and that works pretty good. I also have a lifetime refinishing policy, so if you want me to do it, just send it to me.
CHICAGOHAND
SUGAR GROVE, ILLINOIS, USA.
Well before the ice storm hit and torn down all the lines I was busy learning ring making. Now that I froze my tail off helping get the lights back on I have some time to post my pics. Thankfully we were released from work CHRISTmas eve morning after working 16 days straight 8 of which were 16 hour days with 8 hours off from the time you check out til the time you check back in. When I would come home everyone was sleeping and when I woke up they were still asleep. That is hard on the body and spirit.
It took me quite a while to build the jaws for the chuck and mounting them to the woodcraft pinnacle chuck was fun. I think when I find some money I will invest in a better quality chuck, one with zero slop. The cuttin board is for my mother in law. It fits in a space right under her counter which when needed is pulled out.
MERRY CHRISTmas.
