Opinion- Deer antler, simple or ornate kit?
BigguyZ
Minneapolis, Minnesota, USA.
OK, so I finally have a piece of deer antler large enough to use on a big pen (Gent, Statesman, and the other CUSA kits). In fact, with the recent technique I've learned with using a lathe to drill antler, I've successfully drilled and mounted tubes for a Gent with antler.
However, since it is not likely that I'll get such a large section of antler any time soon (given that antler's that large hunters usually want to keep), I'm wondering if the Gent kit I had the blanks made for is not ornate/ high end enough. Should I hold off, and save the blanks for a Statesman or Emporer's pen? I know they use the same diameter tubes (though not sure about length). Or do you think the simpler Gentleman's pen works better with simpler material?
I'm torn, so I thought I'd ask for opinions...
Thanks!
mick
Decatur AL, USA
Turn it and see how it looks if you think it needs more ornate the hardware the Statesman is the exact match for the Gent. With the Emperor I think the cap tube is shorter IIRC so it could still be done as a Emperor if you wanted.
