Centerband
Mike211
Erie Pa
I was hoping to get some help with making my own center bands. I have poked around a bit and haven't found anything. A couple of you suggested making my own and I have read about people making there own. Can someone either point me in the right direction or help me out please and thank you!!
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
There are probably a lot of ways to skin this cat. The two approaches that I've used are:
1. Glue a piece of wood or other material that I want to use for the center band to either of the barrels & simply turn it as part of the barrel
2. Drill the center band material as needed (typically 7mm for a slimline), turn it between centers and part it down to size - basically creating a replacement center band to slip over the transmission.
Here's a good article from the library on slimline modifications. While there isn't a lot of detailed instruction on techniques, there are lots of good ideas in this article.
http://content.penturners.org/library/pens/slimline_modifications.pdf
ed4copies
Local Chapter Manager
Racine, WI, USA.
For what style pen?
EdGallop41
Stuart VA
I used a broken twist mechanism (transmission) and slid it into a comfort center band and used it on a Longwood. Slimline bushings are not expensive but to get something unusual I guess I could turn a acrylic blank down on a 7mm tube and cut it any width I'd want. If you check with a jewelry maker they may make you some 7mm rings. A gold nugget would look nice on the right pen. The possibilities are plentiful.
Mike211
Erie Pa
Thanks for the idea Ed, I happen to know a jewelry maker. I haven't seen him for years, I will have to try and track him down!!
Ross
Topeka, KS
I have turned center bands by gluing a scrap of brass center tube in a short blank of the material I want to use for the center band. I have used both matching material and contrasting material with success. I then turn the center band between 7mm bushings.
