Tea Clipper
I just put a few of these button clicks together this afternoon and ran into a 'problem' if you don't know the secret. I just got these kits from BB and noticed that the spring was not on the refill like I'm normally used to. Well, it's easy enough to put a spring on, right? I just slipped it on the end and noticed it went on pretty easily. Well, after assembling the pen, I tried out the clicker and noticed that it was very inconsistent. Sometimes it would work fine, other times it would not retract the refill - either partially or fully. [}] I've always had good results from these button clicks in the past, so this took me by surprise. Hmmm... I thought I read something here recently about springs, and I thought that it was kinda weird that the spring just slipped on so easily... so I took the spring off and turned it around. It became immediately apparent that the other end is smaller; I now realize that the spring is tapered. With the spring in the proper alignment, the refill feels much firmer when you put the pen back together and after a dozen or so test clicks, not a single failure. So how about that... it's not just a spring, but a tapered spring. Doh! [:I]
