At that price, it does seem hard to pass up. I'd jump on some while they have them in stock if I was in the market. The satin silver finish is not the most durable, but it's better than 10k gold. The threads between the cap and body are metal on metal rather than metal to plastic like the higher end kits, but again, at that price, it's not unacceptable. Personally I really like these pens turned closed end rather than using that goofy looking little black sleeve, and it's not that hard, really. Instead of buying a b mandrel and bushings, I would invest that money in a dead center and good 60 degree live center if you don't already have one. Those two things and a cheap dial caliper from ebay or harbor freight, and your ready to turn between centers. If you already have an adjustable mandrel, all you need to be able to turn closed end pens is a drill bit that is just a tiny bit smaller than the threads on your mandrel, and an insert made from a 7mm tube and turned to just fit inside the tube of the sc pen. all you have to do is drill the lower blank with the small bit about a half inch deeper than the length of the tube. then redrill with the v bit deep enough to glue in the kit tube. then just slip the insert onto your mandrel, slide the lower blank over it and thread the end of the mandrel into the smaller hole in the blank. The insert will hold it centered, and the threads will hold it on after you move the live center away to shape and finish the closed end of the blank.
