YouTube.. sharpening a bandsaw blade.Work Great
warren, michigan, USA.
Hello, on you tube is a video on how to sharpen a bandsaw blade with a dremel tool and cut off blade. Its fast and works great I have sharpened the same blade 3 times now and its almost like new. Check it out this will save a ton of money for you guys like me who use the bandsaw everyday. Not great for high tooth count, but I use 3-4 TPI a lot. I hope the link works, i have never tried to link anything to a post. Good Luck, Victor
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/-AnDvUqe1Ac&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/-AnDvUqe1Ac&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
Originally posted by Firefyter-emt
Hmmm... my blade is 115", that might take a while! :D
That means bigger savings than buying a new blade too. ;)
I've been sharpening my bandsaw blade with Dremel but in a different way. I'll try this style next time.
I can do a 93-1/2" 4 TPI blade in ten minutes and have only used this method a few times. As I said its not for a high tooth count. It does work really well, and you can sharpen as fast as he does in the video with goo results. Its worth a try before you drop another $10-$25 on a new blade. Victor
I wonder how that method would affect the tracking and drift of a blade? I have a smaller blade on my saw that drifts bad to one side becasue it accidently hit a steel guide block because I forgot to move the thrust bearing forward when swapping out a wider blade one day. It's a fine tooth, but might still be worth giving it a shot to see how it works. It was a great blade for scrolls.
With my current method, I get to that problem after the 3rd sharpening. Still, I got more from my blade than I would have if I didn't sharpen so I am not complaining.
Tried it this morning and worked great.
One note...make sure you make grinds as even as possible on all the teeth. Obvious but if not done, the longer/protruding teeth will be very grabby. The sharpened blade cuts like new except the grabby part. Tested it on TX Ebony and it didn't complain a bit. Sharpening my 72" (3 tpi) blade took about 5 minutes. Surely worth my time and maybe I'll get better and faster in time.
I sure will use this style of sharpening now.
BTW, I used a Dremel with what I believe is 180 grit diamond lapidary bit.
Just tried it on a 115" 4 tooth blade and it works well. Took me about 12 minutes total and it brought a dead blade back to life.
Just sharpened my blade for the fourth time, and I think I can get one or two more with out losing to much tooth set. This really works well, just use the cheap brittle cut off wheels, I have been getting only one or two sharpenings from one disc(just so brittle). dario you will get better and faster, I have after only5 times. Glad I had saved(not sure why at the time) my worn out blades, now they will have new life. I figure this will save me hundreds of dollars just over the course of a year. Good luck, Victor
I am afraid of brittle things spinning fast. I'll stick with my diamond bits. They are made in China but works great.
I really hope so. :D
I do this sort of thing all the time. You ask why? What's wrong with you? ;)[}:)] LOL
