Using Pin Chucks
bjbear76
Louisville, KY 40299
I spent some time over the weekend delving into the world of kitless and closed end pens. One issue I ran into is getting the drilled blank to turn true on the pin chuck - I keep getting a wobble. The blank is well seated on the pin and it turns fine, but results in a slightly out-of-round condition. Is there a trick to mounting the blank on the pin chucks?
Bill,
I HAD one pin chuck that was a loose sloppy fit into the brass tube. The slop allowed the tube to skew to the side enough to be a problem. I could compensate with shim stock, but the hassle was not worth the replacement cost, and got an expansion style to replace it.
If there is not slop inside the tube, time for a dial indicator and careful checking.
Maybe I should clarify a bit. I'm turning an ebonite blank for the cap end of a fountain pen. I've drilled up to 1/2" of the closed end of the blank. Since there's no brass tube, is it possible the pin is causing the blank to skew a bit when it "grabs" in the flat of the rod?
How tight is the rod when you're pushing it into the blank?
The ones that Rick Herrell made for me were a perfect fit, and it was a struggle to get them into the hole because they were acting like a piston in a closed cylinder. (He machined a small groove in the next ones he made for me, to act as a pressure relief :biggrin:)
If you can push the blank onto the rod with no effort, it's too loose, and you will get some twist when the pin locks in place.
I use pin chucks very often. I would say two things:
First, if the piece is on the chuck without pin and if I pull it suddenly off, I want to hear a "ploc", something like the sweet noise of a cork out of a wine bottle. If not, the pin may hold it tight, but it will be out of center.
Second, a pin chuck is great for finishing/sanding, not too bad for very light final turning, but very clumsy for roughing. So I use the tail stock as long as possible, which mean a little extra-length ebonite I turn out at the end.
Hope it helps.
Sounds like a sloppy fit and the ebonite is not held straight.
If it's rod, insert as close to the check as can get, I have a small chuck with center drill that I placed a wobbler on to make sure concentric then marked the MT with marker as to fit in rail stick same place each time
Once the rod spins at high RpM the center is clear , I sit in a chain so eye level and make sure nail center
The switch chuck to drill
Best to drill small the step up to size as can get chamfer with larger bits and first few mm of bore may be larger , another tip is drill 2mm in reverse as slow speed to start the bore then switch back
Different materials drill best at different speeds some need some lubricant that part is trial and error but don't force ease in, take out cool lubricant , brush off swarf the. Drill again
Should hit center every time
Otherwise your chuck is not true , a dial indicator will help, more then .0002 you got an issue , maybe bent pin jaw or simply chuck or insert not threaded complete to lathe stock
Sent from my iPhone using Tapatalk Pro
To add then loose Jaws and slip rod out to desired work space , if removing completely sometimes
I make and trade the pin jaws as to place back in same spot when rechucking
