Subliminal
I just set up my shop for penturning and purchased all needed stuff. My problem is I started with a 7mm pen kit. I drilled the blank, roughed it up glued the 2 halfs in place, cleaned up the ends with my new barell trimmer wit 7mm shaft and now my problem. The 7mm bushings that they sold me fit te #2 shaft perfectly but I can't get the 2 pen halfs to go onto the shaft. At first I thought maybe I bought the wrong # 2 mandrel but after calling the store they said tat is only one size. The only other thing I can think of is the pen kit has defectivelly small tubes. They did fit in te drilled holes after drilling with my 7mm bit but that was it. My mandrell measures 6.20 mm and the tubes measure 6.10 mm. I'm seeing the problem as I write but could a large retail store like Woodcraft carry a product line that is careless in their packaging of parts or am I not seeing something.
