Oh, well the parts are in [
] Cost to date, $0.00 (well, I did have to make a 15 mile round trip to pick it up)
The treadmill has a pro date of 1997 and the original owner confessed to not using it all too much. The motor is out and is a 2 1/2 hp 17.2 amp (7099 rpm) [:0] Motor and it has been bench tested before and after removal. There is also a nice chunk of the frame I will cut out for the motor mount, this will fit into a mortice under the table so it is cleaner. I also gained a nice piece of laminate covered 3/4" MDF and a sweet roller for a stand I will make for it, free table saw out feed! [
] I have not dug into the controls yet to see what I want to use, the speed control is seperate and I can change it to a rotery knob eaisly. The rest may be harder.. I did get the pulley off the motor so that made me happy, not I have to figure out what to do for a pulley set up.
I have a few questions. What "ideal" pulley sizes should be used on both ends? I plan to keep the 4 stack at the headstock (I have to to be honest) What pulley should I run on, and what size to drive from the motor. Next, the motor had a heavy cast iron pulley that may of served as a fan, do I need to worry about a fan on this motor if it is out in the open? And last, but not least, the motor hooks to a choke before running to the controler, what is the purpose of that?
Here are some photos..
