tap and die
Indy-Pen-Dance carries them, but depending on what you need, it may be hit or miss, with a few items out of stock. Looks under "Tools" on their website. Indy~Pen~Dance
I have no association with them, I just happened to place an order with them last night. (They are running a "Birthday Bash" special, use code "BB" to get 8% discount).
Thanks everyone!
i consider myself a novice, but looking to expand my knowledge. I know the advantages of using multi start threads is quicker removal of the cap. On the internal parts do you use standard single start threads?
Adam
Adam for the connections other than the cap, most of us will use a single start. If it helps about the best choice for the section to body would be a M9 x .75. You can also go with a M10 x 1 but the first one gives you a little more meat in the body wall where you cut the cap threads.
