Druid
For those who may be interested, found this in Craig's list (Washington, DC area)
http://washingtondc.craigslist.org/doc/tls/1432073103.html
Sherline 5400 CNC Mill Enclosure Cabinet $200 OBO
Sherline 5000 CNC Mill Enclosure Cabinet
This is an extremely RARE item. I know if I had one of these sherline mills this item is a MUST! Built exclusively for the Sherline 5000 series CNC/non-CNC mills. The enclosure has threaded mounting holes for both the sherline 12" and 14" mill bases. This enclosure or mill cabinet completely houses the entire mill, including all (x,y,z) axis stepper motors, as well as the spindle motor. This unit will capture and keep all cutter debrie, filings, lubrication, etc - leaving your work bench and/or work area clean as a whisle.. When cutting/milling is complete, just vacuum up the inside and done.
