sanding problem
avbill
San Bruno, CA, USA.
After using the prochuck on a PR blank, I started sanding with 600wet/dry. 600,800,1000,2000, then mm to 4000 to 12,000 I saw scratches and re did the sanding again. I still see scratches. Could the stratches be below the 600 mark?
I always start my PR sanding with 220. Then 320, 400, 600 and then MM. It could be that your 600 is not getting out some of the tool marks.
If they are circular scratches you could try stopping the lathe and sanding back and forth between grits. I have never used a prochuck so I don't know if that would leave scratches or not. Sometimes, if I finish with a skew, I can start at 320 and be fine. I actually think someone really good with a skew could go right to micromesh.
I too would lower my starting grit. That and sanding end to end should eliminate the scratches.
Buffing is the only way I've found to completely remove scratches. They are especially noticeable on darker acrylics/resins.
It's just too difficult to consistently remove all of the scratches from the previous grit without oversanding, which will lead to problems with the next grit. It is a snowballing effect that gets worse with each successive grit.
I've solved this by sanding through 12,000 grit micromesh and then buffing with white diamond. Give it a try and see what you think.
I may start as low as 150 grit to shape the blank if I'm not 100% happy with it after turning. For PR and my skew I can start at 320 or even 400 grit. I had the same problems as you have- to fix it I started sanding back and forth (lightly) on the blank after sanding with the lathe on (cross sanding), then I moved up grits to 400 each time doing the same technique. I use the sanding pads (micro mesh) to around 10,000 (i've stopped going to 12K as I found it really didn't do much). What really fixed the scratches was getting a buffing wheel. I now use the 2 wheel set that PSI advertises as the Barry Gross set- I run both my PR and ca finishes on it at the end and it makes the surface like glass and takes out the scratches.
