Resifills square box and BT blanks, Vine and Colonial Red Gum PEN blanks...!
robutacion
Australia - SA Adelaide Hills
Hi peoples,
Here are some of the Platypus Gum Burl termite carved wood, made into BOXES and Bottle stoppers, using PR coloured resin. Also some pen blanks made from the same wood and with the same process, Resifill...!
I brought in also, 30 of my best VINE Shiraz Red PEN blanks and finally some of those Colonial Red Gum under water cure wood that I had found among my knife blanks (3 knife handle blanks) that I totally forgot I cut.
These are the very same quality as those I selected to sell here, a few months ago, they were all exhibition grade, the same apply with these ones.
The only difference is that, and unless I find some that I don't know I have, these have a very good chance to be the very last ones I will ever sell in this grade as I still have some second grade on sale on eBay, these were cut to give no waste from the size I cut my knife handle blanks at (150x50x35mm) so, there are 2 groups, one at 17mm square and the other at 14.7mm so, you will have to be accurate with your drilling...!
Please remember, these blanks are in Australia...!
Freight cost to USA and Canada (please, request quote for any other countries).
All prices are quoted on the Regular Air-mail option, by Australia Post.
Note: An USA Customs sub-charge of $9.00 will apply, with any order to the USA over the 500gr total weight limit
*- 250gr. (USA & CA) -- AU$10.50+$1.50(box)=AU$12.00
*- 500gr. (USA & CA) -- AU$17.25+$1.50(box)=AU$18.75
*- 750gr. (USA & CA) -- AU$24.00+$2.00(box)=AU$26.00
*- 1kg. (USA & CA) -- AU$30.75+$2.00(box)=AU$32.75
*- Other weights, please contact me for quote...!
When you add on the various blanks you are interested in, please remember that the postal box+bubble-wrap+paper work+wrapping tape is approx, 85gr for the small box and 100gr for the next size up.
Weight adjustments are possible by removing the square corners of the blanks. This is a normal procedure to void extra freight charges, unless you advise, to not remove them...!
Pen blanks size average is 21mm square x 130mm long, with exception of those clearly marked differently...!
Please, post here the number of then blanks you are interested in so that other can see what is still available, thank you...!
You will be then contacted with the payments details...!
PAYPAL, only.
*- Platypus Gum Burl #26-B termite carved wood filled with PR coloured resin, BOX square blanks
*- Platypus Gum Burl #26-B termite carved wood filled with PR coloured resin, Bottle Stopper blanks
*- Platypus Gum Burl #26-B termite carved wood filled with PR coloured resin, PEN blanks
*- VINE Shiraz Red PEN blanks, exhibition grade 1 to 10
*- VINE Shiraz Red PEN blanks, exhibition grade 11 to 20
*- VINE Shiraz Red PEN blanks, exhibition grade 21 to 30
*- Colonial Red Gum #9-S cured under water PEN blanks @17mm square in 6" and 5"
*- Colonial Red Gum #9-S cured under water PEN blanks @14.7mm square in 6" and 5"
Cheers
George
I'll take, please:
Group 26-B PEN BLANKS: # 1A, 2A, 3A, 4A, 5A, 1B, 2B, 3B, 5B, 6B, 7B
Shiraz Red Pen Blanks: #2, 3, 4, 5, 7, 8, 21, 25, 27, 28
Shipping to Canada. You may have to grind off the corners
Please send cost, and your advice as to box size.
Thanks, Mal
For anyone interested, I had to back out of the purchase of those 4 box blanks. They are available again.
Reason for backing out was the $68.00 for shipping(not counting the $9.00 for customs)
Just can't swing that much for shipping alone.
Good luck
Good luck
Thanks turff49, that was the right thing to do, thank you...!
So peoples, I need to get those (X) over these blanks, I may have to take a new pic as I used the original for the editing and it can't be reverted, however the blanks are available for any and/or all purposes...!
Cheers
George
