PSI Majestic Jr.--Need Some Help
Randy_
Dallas suburb, Texas, USA.
Anybody out there made one of these kits??
I was working on my Pen Reference Chart and discovered I have some conflicting information. It appears there could be a mistake in the bushing dimensions on the PSI instruction sheet. There is also some disagreement on what the correct drill sizes should be for this kit.
If someone could measure the tubes and the bushings and let me know what drill sizes you are using, I would appreciate it very much.
Thanks.
Randy I have never made this style so I cannot help you, however, there are quite a few kits that state a certain drill bit size but penmakers prefer a different size for a better tube fit.
Do you state the manufacturers recommended drill bit size?
I've made one of these. There was a problem with the instructions included in the box the kit came in. It had you drilling the top and bottom blanks with the wrong bits( just reversed, as I remember). You can download instructions from PSI web page that are correct.
DonHO
