JodyS
I'm having an issue with my lathe, and was wondering if anyone has seen this before or has any suggestions.  I have a two year old Harbor Freight 10x18 lathe.  A year ago, I replaced the original motor with the PSI VS replacement for midi lathes.  It was a completely plug and play swap...very easy.  Worked well to begin with, but over time I'm having more and more issues with the motor.  VS means I can change the dial and change the speed, not that the speed will go up and down while set at a single setting!
Here is a short video I took this morning. The belt is set in the middle range, so high speed should be 2800 rims. 2/3 of the way through the video, I dial the speed down to low, and you can hear that it nearly comes to a stop.
Has anyone seen this before? Suggestions? Help!
https://youtu.be/UiiWMaJxkd4
