lmarti13
I am curious about what other people with Beall collet chuck see for run-out. I just received a Beall from CSUSA and when I put a mandrel into it, I get 0.005" runout where the mandrel just exits the collet. Run-out of the 1"-8TPI chuck body is good (0.001"), but the run-out of the inside taper (where the collet seats into) is 0.004". The collet doesn't want to center with this run-out. As a check, I also chucked the same mandrel into my drill press and measured less then 0.002" run-out.
Does anyone see similar run-out on their Beall?
Lynn
Lynn
