DonWood
Hi Everyone - I have a question concerning the final step when using a CA finish.
Normally after I put my final coat of CA on I then micromesh it from 4k to 12k.
However, then if I try to use the Micro Gloss, which is the same product I get great results with on the acrylics, most of the time it dulls the CA down instead of giving it a high gloss, and I have to redo the CA finish, micromesh, then just to go the buffer using White Diamond skipping the Micro Gloss.
I would like to use the Micro Gloss since it should give me a much superior gloss, but I am having this problem.
Anyone have any ideas? Am I not waiting long enough for the CA to harden before doing the Micro Gloss? I normally try to use the Micro Gloss right after I finish with the Micromesh.
Any suggestions would be appreciated. Maybe I should start using Brasso or something like that instead of the Micro Gloss?
Thanks for the help.
