Poly problem
StatProf
Richardson, TX, USA.
I made some of my first stoppers and decided to finish them by dipping them in fast drying poly. Gorgeous and glassy. One problem, not so fast! I did it indoors and 2 days later it is still a little tacky. Ideas?
Thanks,
Kyle
That's your problem. Not sure how to fix it though. You may have to remove the finish and use a different one.
Quick search came up with this:
Woods like cocobolo have a certain amount of natural-occurring oil in them. When you coat them with an oil-based finish, the oil in the wood itself prevents the finish from oxidizing and curing properly. So you have a few options. You can either use something like shellac or lacquer instead of an oil-based finish. Or, we can seal the wood first, preventing the oil from contacting the oil based finish. Shellac is a great sealer for this purpose. A good coat of a 2lb cut (I use Bullseye Sealcoat) dewaxed shellac should do the trick. Sand lightly with 320 after the shellac and proceed with your oil-based finish. Now keep in mind you want a straight varnish at this point (not an oil/varnish blend). But you should have no adhesion issues with the varnish at that point.
If it isn't the wood, dipping could be the problem. You have a film thickness that is about 10 times thicker than the usual wipe-on/wipe-off application of a poly that drys overnight. You should expect it to take 10X longer to dry.
I have finished pens with a similar dipping method in a home-brew oil finish that is similar to Waterlox, and it takes about a week for them to be dry enough to buff in the summertime when the humidity is at its lowest, and 2-weeks in the winter in a shop that is kept at 65F during working hours and turned down to 55F the rest of the time.
I had a pen that i used poly on and it was still tacky the next day, I heated the oven to 125 put them and let them set a couple of hours.
