Platinum Pen Problem
ttpenman
Ashland, WI, USA.
I turned my first CSUSA platinum pens this weekend. 2 Gentlemens and 2 Jr. Gentlemens + 2 platinum letter openers. They came out quite nice. But, when i looked them over last night a noticed that the plating was frosted in some areas. Also the refill was discolored. Would not wipe off. I am assuming that the plating reacted with the CA that I used to assemble the pen. (seems to be in the right areas) Has anyone had a similar problem? After mild panic that my days work was lost, I was able to wipe off the discoloration with acetone. (CA solvent) I thought that was the answer but the problem has come back today. I am hoping that the CA fumes will eventually fade. The frost seems a little less today than last night. This has never happened with any gold plating.
Any suggestions? Thanks.
Jeff
Rudy Vey
South Plainfield, NJ, USA.
Same happened to me on my first El Grande Streamlined Pt.
Help: Use epoxy glue for glueing pen parts together, no fumes here. Also, if you have to use CA do not put the glued pen/parts in a sealed container (like plastic bag, pen box or else), let them just sit overnite so the fumes can dissipate.
Rudy
Daniel
Reno, NV, USA.
I have heard several times that the Platinum finishes will react to CA.
the satin nickle finishes also have a problem of yellowing after time.
melchioe
Mukwonago, WI, USA.
Do they react to fully cured CA? Wow, if so, another argument for Gorilla; but has real impact for CA finishes. Will letting parts sit to fully cure help at all? Does an accelerator (before assembly, of course) help?
Scott
Blackfoot Idaho
I have been using LocTite blue to assemble my pens. I don't think I have seen any effect on the platinum finish.
Scott.
jrc
Bristol, Vermont, USA.
They use super glue to get finger prints off things. They put some in a small container and item with finger prints next to it in a larger container and seal it up and the fumes makes the prints look white. I made that same mistake with the gent jr and now I let it set over night and now I have no problems.
