Pen mill insert sleeve for a Sierra
C. Scott
Alvin, Texas, USA.
It's probably already come up, However, I discovered something quite be accident in preparing blanks for Sierras.
A 10mm tube will fit perfectly inside the Sierra tube (without binding). Then you can use your pilot shaft for 10mm tubes with your pen mill to achieve blank "squareness" :D
Even a blind hog finds an acorn. ;)
I thought everyone knew this already. Heck, if you watched the video of BB make the Sierra, he even says and shows that the tube is the correct size for a sleeve.
Unfortunately, Mikey, a lot of us forget the things we know and have to be reminded from time to time.[:(].......sometimes several times![;)][}:)]
