Parts needed
cmccarter
columbia, sc
I was working on a Traditional Rollerball Kit today and managed to crack the small plastic funnel that screws into the cap and provides the snap on capability. So I opened another kit and tried again and again the plastic part cracked. so 2 kits and one blank screwed up. Anyone know where I maight be able to find the plastic funnel pieces, You can be sure I won't be using any more of these kits when these are gone..
chester
Have you asked your source for the kits?
I am not familiar with the traditional, but I have had very good success going back to the vendor for replacement parts.
You might want to check your tubes
I was having similar trouble, I found my end mill was rolling a little bur inside the tube. Fixed that and my troubles went away. (those troubles anyway).
I would also check with the supplier, they might know of an ongoing problem.
Best of luck,
G
psi CUSTOMER SERVICE
After contacting PSI with the problem, they sent me replacement parts at no charge. Guess you can't complain with customer service like that.
chester
