redfishsc
I've been looking for a smaller pen for ladies that uses the Parker refill and was hoping that the black-top Euro parker from Berea/Bear Tooth would do the trick. I also liked the idea of not forming a tenon, but rather parting down to the tube for the center band.
Anyhooo, here is what I've found:
1) It's almost the size of a cigar pen. Sorry ladies! It is a very elegant kit though, I like the look and feel.
2) If you don't part off the amount of wood needed DEAD NUTS the kit won't work right. If you read the instructions, they tell you exactly what to make the tenon and do it with almost an apocalyptic tone, as if there will be weeping, wailing, and gnashing of teeth if you are off by even a nanometer. AND THEY ARE RIGHT. I used my digital calipers to get the right measurement and the kit still didn't fit together right.
3) This kit uses the IDIOT DESIGNED transmission type that the flat-top Americans use. Ie, double twist------ and if you twist it one of the directions, it starts unscrewing from the tranny holder rather than extending the writing tip. Very, very, very
cheap feeling--- it is this exact reason I do not try to market the flat-top Americans, I don't want people unscrewing their pens by accident when trying to extend the refill to write with. Yet, you CAN'T glue the tranny to the tranny holder b/c that's the ONLY way you can put a refill back in it.
Why oh why could they not have used a transmission like the one in the cigar pen? It's a double action but you can glue the tranny to the holder b/c you can unscrew the nib and stick a refill up in there.
